08-24-2007
tiny 2 cycle question
I was given an old dink motor; an air cooled 2 cycle 1.2 HP Sears that was actually made by Tanaka. Story is - "ran when I put it away, but that was a few years ago". Anyway, it doesn't work for me now. So I check the plug and see it sparking. I spray some carb cleaner down into the hole while the plug is out and when I put it back in, it cranks and dies quickly thereafter. So I am thinking the problem is fuel, not fire. I unscrew the trap and then when I turn on the gas it trickles in. I put the trap back, take the hose off going into the carb, turn gas back on and nothing comes through. So I think I need to replace both those hoses and clean the trap (including inflow and outflow). That is, unless the system depend on "suck" from the engine to move the gas. It does make a different sound depending on the gas adjustment when I try to crank. Spraying cleaner (pretty much same as starting fluid) into the choke of the carb also turns it over for a few revolutions. So, what would you do next? I think I should replace the hoses and clean the trap.
