Pearson 34 Centerboard replacement - SailNet Community
Blogs
Old 08-25-2007
hawke is on a distinguished road
Does anyone know if there is a source for a replacement for the centerboard board on the P34?
Old 08-25-2007
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
A centerboard on a 34' boat? (With a cored hull, no less.) Don't you mean keel? That would have to be custom-crafted, I would imagine.
Jim
s/v Abracadabra
1976 Pearson P30
Old 08-25-2007
SEMIJim-
I beleive the P34 was a stub keel/centerboard design, with the bulk of the mass in the stub keel. The centerboard was primarily to generate lift and help prevent leeway.
If the centerboard is unweighted, which is the case with the centerboard on my boat, you might try Foss Foam and see if they make one. If it is a weighted centerboard... that'll be a bit more difficult.
Old 08-25-2007
PapillonDory is on a distinguished road
Builder/Designer
Builder: Pearson Designer: Bill Shaw
Dimensions:
LOA: 33'9" Beam: 11'2" Displacement: 11,750 lbs.
Draft: 3'10" / 7'6" Ballast: 4,660 lbs.
SemiJim: I think the gent means just what he said....Centerboard on a 34...yep there is such an animal after all...
Old 08-25-2007
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
The Pearson centerboard models were very popular along the east coast, primarially the Chesapeake Bay area... I bet that SailorMitch, who lives in the area, and is a big Pearson fan, may have some pointers. PM him, and PLEASE post on your findings. I am investigating a Pearson centerboard model myself.
Good luck,
Ed
Old 08-25-2007
BTW, might want to try D&R Marine, as they used to have the molds and would make a new board. 508-644-3001
Old 08-25-2007
SEMIJim's Avatar
SEMIJim-
I'll be damned. You learn something new every day .
I actually looked before answering. Didn't look hard enough. Turns out they made two versions of that boat: A "centerboard version" and a "keel version":
Jim
s/v Abracadabra
1976 Pearson P30
Pearson 34 Centerboard hawke Boat Review and Purchase Forum 2 08-22-2007 11:56 PM
Centerboard Penant Replacement BruceTucker Gear & Maintenance 1 09-07-2005 07:05 AM
Pearson 36 vs C&C 37 dnr Boat Review and Purchase Forum 1 11-16-2002 05:07 PM
Pearson 35 Centerboard Cable lazypointer Gear & Maintenance 0 12-04-2000 07:37 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
