Old 08-25-2007
chappyonice is on a distinguished road
A little "direction" on the Y-valve...
To this point, we've been using just the marina restrooms when docked and pinching tight when out on our short daysails . That got me thinking, I had better understand how to effectively use the head on our new used boat (1999 Bene 311). Read through the manual for the Jabsco head, no problem there. There is one catch however - we have a Y-valve in the system which directs the flow to either the holding tank or the overboard discharge. In the spirit of making sure we do things responsibly, I need to figure out which way the Y-valve goes before we ever have to use it. I'm linking to a picture of the valve and was curious if someone else had the same model and could explain which setting is which direction. If the red lever points up, does the flow go up? Or would the flow go down because the set of arrows pointing down is exposed when the lever is up? In the pic at the link below, is the flow up or down?
Picture of the Y-valve
Thanks!
Old 08-25-2007
bsfree's Avatar
bsfree is on a distinguished road
You could always give a couple of clean flushes and see which direction gets water into the holding tank.
All the best
Old 08-25-2007
erps's Avatar
the pointy end is the bow
I can't tell by the picture either. I'd close the overboard discharge thru-hull and then try and pump fluid through the head in each y-valve position. Should flow in one position and meet resistance in the other position. They you'll know.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 08-25-2007
trantor12020's Avatar
trantor12020 is on a distinguished road
I was in similiar predicament. My Y-valve is different make. I found out that when the handle covers one of the arrows, the 2 displayed indicates direction of flow. Maybe you could disconnect one outlet hose to confirm.
Old 08-25-2007
It is probably designed so that whichever arrow set is uncovered is the functional setup for the given handle position. If you knew who made the valve, it would be simple to ask the manufacturer if they're still in business.
Many of the newer valves have the arrows on the handle, to make it very clear what is going on.
Old 08-26-2007
Found the answer
Just to close out the thread and provide some documentation for those who might look it up in the future, I went down and did some experimentation today. The exposed arrow path is the path which works. So in the picture, that would be down. I also found that flow down is the through hull and flow up is the holding tank (therefore it is now in the FLOW UP position ).
Thanks to those who replied and happy sailing!
Hot water heater bad valve? bestfriend Gear & Maintenance 4 06-22-2007 09:12 PM
Replacing SeaCock Gate Valve with Marine Ball Valve saurav16 Gear & Maintenance 30 06-15-2007 10:52 PM
Thru hull stuck Jotun Gear & Maintenance 25 03-11-2007 08:20 PM
Water Heater By Pass Valve MHRitter Gear & Maintenance 2 10-31-2002 09:41 AM
Plastic Through-Hull Valves and Valve Flanges John Kretschmer Gear and Maintenance Articles 0 05-27-2001 08:00 PM
