Lubricating heads? - Page 2 - SailNet Community
Blogs
  #11 (permalink)
Old 08-26-2007
Joesaila's Avatar
1977 Morgan OI 30
Joesaila is on a distinguished road
Yes, its silicone grease. I appreciate the info about the corn oil causing 'more' odor. The vinegar makes sense, I've seen some thick rock hard scaling so I'll give it a try. Too bad there was'nt a lubrication port on the Y valve, accessing mine is really tough. When this one goes I will get the marelon or bronze. Thanks for the tips!
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
  #12 (permalink)
Old 08-26-2007
camaraderie's Avatar
moderate?
Joe...If you already have significant scaling in your hoses and valves, you may need to be more aggressive than vinegar. Muriatic acid pumped into the lines is the way to go. Then...once you are clear...you can use vinegar for maintenance.
Full procedure here:
http://www.boatus.com/boattech/casey/04.htm
Rescued sailor heads home - Daily Pilot NewsReader News Feeds 0 01-08-2007 05:15 PM
Canadian destroyer rescues 3 sailors in storm; heads for another ... - Canada.com NewsReader News Feeds 0 11-09-2006 09:15 PM
Clipper heads into storm (Jersey Insight) NewsReader News Feeds 0 05-31-2006 04:15 AM
Sailing Heads to Nationals (The Harvard Crimson) NewsReader News Feeds 0 04-25-2006 05:15 AM
At sea. Clipper Round the World Race: Jersey Clipper heads back to sea @ BYM Sailing News NewsReader News Feeds 0 04-18-2006 05:16 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
