Old 08-25-2007
sailhog has a spectacular aura about sailhog has a spectacular aura about
First haul-out
Sailed my boat down to the yard yesterday with my two little girls, and had it hauled today. No blisters whatsoever. That's a big 10-4. Could the learned pannel give me a quick check/to-do list while she's out of the water? The thru-hulls look good to me. Anything specific I should do in that dept.? Appreciate every last one of you.
Old 08-26-2007
NOLAsailing's Avatar
NOLAsailing is on a distinguished road
1. Check your zinc(s). If they are at all deteriorated, replace them while the boat is out of the water.
2. Check your cutless bearing. If there is significant side-to-side movement, it may need to be replaced.
3. Check your prop. If it is at all pink or doesn't resonate, it may have had the zinc leached out. If it is dezincified, it will be brittle.
4. Check the keel/hull joint, though if there is a problem there, I'm sure you would have noticed it by now. Likewise with the bottom paint.
5. Check the strut.
6. Check the rudder, gugdeons, pintles, etc.
-Jason
Old 08-26-2007
bestfriend's Avatar
Hitchin' a ride
bestfriend is a jewel in the rough bestfriend is a jewel in the rough bestfriend is a jewel in the rough
When you paint the bottom, make sure you mark it with "this side down", the yard will really appreciate your attention to detail.
And do all the stuff he said above. Plus, if you want to change your stuffing box/packing gland etc., nows the time to do that.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
Old 08-26-2007
I'm one step ahead of you, BF! Already burned those words into the hull with a blow torch. Yard guy pretends to be "all upset," then he explains he already knows which side goes down. Pretends I'm stupid. He's good at playing pretend. Real good. The mast, he said, goes straight up in the air. I told you: These guys are good! When the mast is straight up in the air, the bottom is down, in the water. I've got to poop. Be right back.
Old 08-26-2007
Also, if your through-hulls are bronze, scratch the surface and look at the color. If they appear pinkish, then they're probably starting to de-zincify, and will need replacement.
Old 08-26-2007
bestfriend's Avatar
Hitchin' a ride
Write "I'm with stupid" with a big arrow. Take a picture while he is sanding next to it.
Vaya con Dios
Old 08-26-2007
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
Wouldn't that be a great name for a boat?! You could even put the arrow decal pointing up towards the cockpit. Wouldn't it be fun hailing someone?
forida haul out renu General Discussion (sailing related) 1 07-19-2007 12:20 PM
Haul out in Gulf Shores Alabama? j34035 Gear & Maintenance 8 11-30-2006 09:53 PM
Best Haul Out in Caribbean for Paint/Refurb kaakre Gear & Maintenance 2 10-19-2006 09:50 AM
It's no breeze to haul sailboat off beach - Asbury Park Press NewsReader News Feeds 0 09-06-2006 05:16 AM
Cat haul out in W. Florida dsprygada Gear & Maintenance 0 05-15-2004 05:45 AM
