08-27-2007
It could be a worn valve, or the valve could have mineral deposits that are preventing it from closing completely. You could try removing the valve, soaking it in vinegar to de-lime it, and then replacing it... if the cause is mineral deposits, this may fix it... otherwise, just get a new valve and replace it... they're not all that expensive.
