My engine is getting too hot.. - Page 3 - SailNet Community
post #21 of 31 Old 08-27-2007 Thread Starter
Rockter,
Shouldn't it stay at one temperature value once the thermostat opens the first time?
I had noticed in the beginning of the season that it would get hot (about 100 C) in the first 5-10 minutes, then drop quickly once the thermostat opens to 70-80C.
But now, it wants to stay up at 100C and will even go over if I throttle up beyond low RPMs.
If I keep the throttle lower, so that the engine doesn't get very hot, I notice the temperature guage will rise and once in awhile, it drops suddenly, then rises again.
So that behavior is normal for these engines?
I have heard a lot of people asking about these plugs you mentioned, but I have not touched them, the boat is a 1973. Bought it last year.
groundhog
ps. Sorry about teasing you on the accent, couldn't resist. Half my family is from county down.. (that's cinety dine in irish).
groundhog is offline
post #22 of 31 Old 08-27-2007 Thread Starter
Just checked..
Cooling temp is listed as 75-85 C in the MD6A handbook.
post #23 of 31 Old 08-28-2007
Groundhog...
The thermostat you need to have is the one designed for raw water cooling. There are two thermostat models available, the second one for those owners that have a heat exchanger.... they run hotter. Salt water really scales aggressively at higher temperatures, as a bunch of dissolved salts come out of solution at the higher temperatures, so it needs to be run cooler.
I think you might have the wrong thermostat in there. Pls check the part number. It should be on the packet and on the thermostat. failing that, simply test it with a thermometer.
The thermostat is constantly cycling, as when it opens there is a rapid cooling, and then it shuts again. It's quite a crude animal, but it works ok. Problems start when it sticks open... and you overcool.... or it sticks shut...... then you boil up. I'd sooner have the overcooling mode... stuck open.
It's a very tough motor, very well built, and very heavy. Shame they absolutely savage us for spare parts though. My next motor will be the Japanese Kubota, not because of lack of Volvo quality, but because of the astronomic costs of the spare parts, costs that just about write off the motor if you break something major, and I have. Ten years ago, they wanted 1330 for the exhaust manifold (close to $2600 at todays exchange rate). The motor was 20 years old at that moment. A manifold for the Lister Petter was 185.
Good luck.
Rockter is offline
post #24 of 31 Old 08-28-2007 Thread Starter
Wow, you might want to machine your own manifold for those prices.
FYI: I saw pricing on a new Volvo today...
http://www.marinepartsexpress.com/engines.shtml
Don't know what a D1-13 is, but it is a 13hp diesel for $8450.
Beta BZ482 13.5 HP Diesel w/2:1 Technodrive $5,945
Can't remember where I found this beta price, but have it in my notes.
gh
post #25 of 31 Old 08-28-2007
It was the 40 hp Beta (Kubota) I was looking at.
It looks a good 'un.
Rockter is offline
post #26 of 31 Old 08-28-2007
Oh, and the Beta turns the prop the other way, so I'd need a new prop.
Rockter is offline
post #27 of 31 Old 08-28-2007 Thread Starter
By the way,
I purchased the 5:1 concentrated 1 gallon version of Barnacle Buster rather than buy 2 gallons and pay shipping. I will have enough to make about 3 gallons after I am done. If anyone wants it, let me know. one gal is like $23 and the concentrate is like $66 new.
gh
post #28 of 31 Old 08-28-2007
T37Chef's Avatar
Originally Posted by groundhog View Post
By the way,
gh
Be sure to tell how it worked, hopefully the same results as me
Shawn
T37Chef is offline
post #29 of 31 Old 09-03-2007 Thread Starter
Ok. Here's the update.
Got the Barnacle buster concentrate last week. Rushed down to the boat Friday and mixed up a gallon and sucked it into the engine cooling system.
Let it sit overnight.
The stuff appears like windex. Light blue and clear.
The next day, I started the engine back up and the stuff that came out the back of the boat was chalky looking.
Performance:
Before, the boat overheated on just about any throttle up.
Now, the temperature gauge needle only rises out of range on very high throttle settings. A significant increase.
It took my boat from almost unusable to having an almost unnoticable problem.
I still need to flush it once more. I will also try to pull the plugs on the cooling ports of the engine (volvo MD6A) at some point.
I should have enough concentrate left at the end for 2-2.5 gallons if anyone wants to buy it from me.
gh
post #30 of 31 Old 09-03-2007 Thread Starter
Oh, I also cleaned off the barnacles from my prop at the same time (see my entry on the "cleaning prop" post.
But this action probably reduced load on my engine.
gh
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
