Old 08-27-2007
sanctuarysam's Avatar
purveyor of mischief
sanctuarysam will become famous soon enough
Lower Chesapeake Bay Bottom Paint Recommendations
need some advice on what other bay sailors are using as bottom paint. the boat lives on the lower chesapeake and the ablative on her now is tired and no longer effective.
i read the Practical Sailor recommendations, however they are for Ct and Fl, and i'm somewhere in between.
so, all you chessie sailors, what have you used, what have you been happy with and what didn't work so well.
thanks in advance.
i intend to stick w/ ablative btw.
sam
Old 08-27-2007
camaraderie's Avatar
moderate?
I used to get 2 years out of micronCSC on the lower bay.
http://www.jamestowndistributors.com...g+Bottom+Paint
Old 08-27-2007
Quickstep192 is on a distinguished road
I'm near Annapolis and I use Interlux Micron Extra with Biolux. My biggest problem had been the fuzz that grows on the bottom and the Biolux has helped with that a lot.
Old 08-27-2007
thanks Cam & Quick...
how do/did you deal w/ the prop and shaft using an ablative... a friend recommended using interlux primer. the reason i ask, during my last outing i found significant "crusties" on my prop and shaft causing enough resistance to cause soot in my exhaust and significantly reduced RPMs, after braving the stinging nettles i scraped enough off to correct the problem.
any thoughts?
Old 08-27-2007
moderate?
Sam...I don't think anything works for props and shafts. If you are not gonna use the boat...paint 'em with bottom paint. If you use the boat all the time, they stay pretty clean. It is only when you let them sit for a few weeks that growth becomes an issue. A wire brush and a snorkle was always my solution!
Old 08-27-2007
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Not so. The "Prop Speed" product gets excellent reviews although it is a bit spendy:
http://www.westmarine.com/webapp/wcs...&classNum=null
"Clean bottoms are FastBottoms"
Old 08-27-2007
Cam,
the biggest problem is i'm in SC and she is in Va..i sneak up for a couple of days as my schedule allows (not nearly enough for my tastes mind you)..
so either a bit of hard coat or i get to practice my underwater cleaning techniques..hmm..
By three methods we may learn wisdom: first, by reflection, which is noblest,second is by imitation, which is easiest,third is by experience, which is the bitterest.
Sam
Sanctuary, Sabre 30 mkIII
Old 08-27-2007
moderate?
Well...FstBottoms is the expert...if he says that propspeed stuff works...that's good enough for me. Never heard of it before and wish I had ...the nettles in the Chessie can make the wire brush routine an unpleasant experience!
EDIT: Jeeez...I just took a look at the price! You ain't kidding FST...how long does it last?
Old 08-27-2007
TSteele65's Avatar
Ne'er Do Well
TSteele65 is on a distinguished road
At $50 for 500ml, it better last a decade. In salt water.
Old 08-27-2007
jboatjack's Avatar
jboatjack is on a distinguished road
pull out and power wash
Confessions of a bottom feeder PracticalSailor Gear and Maintenance Articles 9 06-18-2008 04:33 PM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Bottom Paint Compatibility Dan Dickison Gear and Maintenance Articles 0 01-24-2001 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
