08-27-2007
Actually, it really depends on the size of the bilge pump and the length of the wiring run. For a wiring run of 20' one-way, if the pump draws more than five or six amps, it will probably have some issues. With a 10 amp draw, you have over a 1 volt drop in voltage with 16 gauge wire.
Also, if the 15 Amp breaker is tripping, then something else is going on. If the wire were corroded or any of the connections were corroded, it would draw less electricity rather than more, since the resistance would go UP, not DOWN. It is drawing significantly more electricity, since it is tripping the breaker... so there is likely a short somewhere in the wiring.
