- Quick Menu
08-27-2007
weather vane....
What weather vane do you recommend for the masthead? the mast will be dropped soon.
It needs to be a good one, simple and reliable. it does not have to be the most expensive.
I only want wind speed and direction.
Thanks.
08-27-2007
By weather vane, I am guessing you mean a windvane... not something with a rooster sitting on top of it.  A Davis Windex is a good one to get.
If you're new to the Sailnet Forums... please read this POST.
08-27-2007
I'll second the Windex recommendation, though it won't tell you wind speed. For that you'll need a wind instrument, of which there are many choices. I like the TackTicks, personally.
If at all possible, put the Windex (if that's what you go with) on after the mast is re-stepped. The mounting bolt can be installed with the mast on the ground. Then put the rest of the Windex together before you go up the restepped mast and you can just screw it onto the previously installed mount.
08-27-2007
weather vane
WHY???
08-27-2007
Probably so the windex doesn't get damaged in the mast stepping process.
08-27-2007
weather vane.
That's what I figured.
The yard broke mine when they un-stepped my mast. I was going to replace it anyway so I ddidn't care.
08-27-2007
Yes, the reason I suggested installing it after the mast is restepped is to avoid damage. When the mast is vertical enough to be stepped, the crane cable will be dangerously close to the Windex and damage is common.
08-27-2007
Sorry guys... I meant the wee spinning thing on the top of the mast that tells me wind speed, and the wee vane on it that feed me the direction to a wee interface seen by the helmsman.
08-27-2007
humble pie rat
Mine are Datamarine, I think they were original on my 1983 built boat. Still working well.
Ditto to NOLASailing's comments on installing after the mast is stepped to avoid damage from the mast hoist.
08-27-2007
Raymarine, Datamarine, and several others make them. I like the TackTick gear, since it doesn't require running wires down the mast or through the cabin top.  It doesn't require drilling big 4" holes for the displays to mount through either.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
