Transducers - Page 2 - SailNet Community
post #11 of 13 Old 09-11-2007
Alec—
You can't generally install a through-the-hull transducer on a cored hull, unless you are planning on digging out all of the core material. If you do remove the inner fiberglass laminate and core material, you will need to replace it with a fairly substantial fiberglass patch. If you do this repair the wrong way, you risk letting water into the balsa core and delaminating the hull—which is a very expensive repair.
It would help if you said what kind of boat you had.. since the hull design will often affect the placement of the transducer. Forward of the keel, as close to the centerline of the boat as possible is probably a good location, but it will depend on your boat's specifics.
Originally Posted by alecs123 View Post
Ok, since I posted this thread got the transducer.. It a Norcross Hawkeye depth sounder...
Has anyone worked with it? I'm planning on installing it this coming weekend.
I'm thinking on a thru-hull instalation, how ever my boat has a balsa cored hull. I willl "digg" into de ourter layar of fiber glass and then fix it to the boat.
What do you think about this setup?
The transducer also works as a transom mount, but I think it wouldn't work because my boat has a reverse angle in the transome, also I'm not sure if the transducer will be underwater all times.
My rudders is a spade type and I think with the movement, air bubbles will be created.
Any way I'll try different spots, but any information is appreciated.
Thanks
Alejandro
sailingdog is offline
post #12 of 13 Old 09-11-2007 Thread Starter
alecs123's Avatar
type of boat
My boat is a Merit 25... balsa cored.
So you think it's better to install a thru hull transducer to avoid a possible mess with the core? To me is somehow the same, I mean, with a thur hull you make a hole in the boat, with a shoot thru, you only digg from the inside to the outer layer.
I was thinking to epoxy the transducer and then fill the gaps with polyester resin to make sure there are no ways into the balsa.
Perhaps it would be easier to try the transom mount and find a spot where the thing gets wet always (underwater)
alecs123 is offline
post #13 of 13 Old 09-12-2007
If you go with a through-hull type transducer, you really need to pot the hole for the transducer and the fastener holes. It is probably a bit less work than trying to install a through-the-hull, interior mount transducer in a balsa cored hull—since you would have to cut the inner laminate skin, remove the core and then grind out the laminate and build it back back to a thickness of solid fiberglass that is strong enough to withstand the forces on the hull, and then install the transducer. The extent of the repair to the hull's interior is probably a good deal more involved than the just potting a through-hull and fastener holes.
I'm not a big fan of transom mount transducers, since they still require a hole through the hull for the wiring, or a really long wiring run, and are far more vulnerable to damage. Also, having a transom mounted transducer means that you'll have no warning of sudden shoaling and if you're not paying attention, have a much greater chance of going aground. With it mounted a bit forward in the hull, you can often get a bit of warning and avoid a grounding by changing course or backing.
Transducers (for depth sounders) Spencer28 Gear & Maintenance 1 08-01-2007 06:12 AM
Wated: Old Transducers PUC Boat Review and Purchase Forum 1 07-19-2002 11:37 AM
Need old Transducers PUC Gear & Maintenance 0 05-10-2002 01:09 PM
Non-NMEA Transducers PUC Gear & Maintenance 3 05-08-2002 07:30 AM
Hull transducers BenDaniels General Discussion (sailing related) 0 02-22-2001 09:12 AM
