08-29-2007
Thanks... BTW, I would highly recommend not "bolting" the boom brake attachment point in initially, but setting it up so that you can vary it a bit, until you find the proper point for it. I did this by using a line to hold the boom brake padeye in the track at a specific point, and then lengthening or shortening the line until I got the proper position for it. Only after that did I drill the holes and screw the padeye in place.
