Old 08-28-2007
scurvy's Avatar
scurvy is on a distinguished road
Send a message via AIM to scurvy
Corrosion Issue
I have a 1973 Volvo-Penta, MD6A, 2 cyl diesel engine. After doing some repair work to the old girl, I discovered that the top of my lift pump has corroded shut and I can't seem to budge it to get to the screen or the diaphram inside. The bolt comes out easily, but the cover is really on there. It looks as though there should have been a gasket there to avoid such an issue, but that is long gone! The piece is shaped a little like a chinese peasant hat and is very thin where it meets the body of the pump and appears to be quite delicate.
any suggestions on what i might be able to do to loosen it and eventually get this piece off?
Once Again...
Many Thanks!
Chris
Old 08-28-2007
Can you post a photo of the part??
Old 08-28-2007
Rockter will become famous soon enough
A little heat may work... perhaps boiling water. I suspect raw flame will fry the diaphragm and set the diesel on fire or something horrible.
Is the lift pump still lifting OK? I'd leave it if it were.
Old 08-28-2007
scurvy's Avatar
I have been searching for a good picture, but can't seem to find any. I will be going back to the boat this weekend, and will take some shots if I can't get it off.
Old 08-28-2007
SanderO is an unknown quantity at this point
PB Blaster for a week?
jef
sv shiva
Old 08-28-2007
scurvy's Avatar
Where do you get that? I have heard good things about that stuff, but forgot what it was called.
Chris
Old 08-28-2007
Neicy is on a distinguished road
I got mine at the local auto parts store.
Old 08-28-2007
scurvy's Avatar
I'll Try it this weekend! Thanks everyone...
Chris
Old 08-28-2007
Be careful... PB Blaster can damage the seals and gaskets... so be very careful with it.
Old 08-29-2007
all these confusing ropes
dohenyboy is on a distinguished road
Maybe heat it with a heat gun or hair dryer. I would just replace it because it will eventually lose seal when you put it back together
Jib hanks and corrosion kjsailingSpring Gear & Maintenance 5 08-06-2007 11:26 PM
Stainless 101 sailnaway Gear & Maintenance 2 01-28-2005 05:02 AM
Understanding Galvanic Corrosion Kevin Hughes Gear and Maintenance Articles 0 03-08-2004 07:00 PM
Spar Corrosion Demystified Mark Matthews Gear and Maintenance Articles 0 07-01-2002 08:00 PM
Thru-hull Corrosion Mark Matthews Gear and Maintenance Articles 0 08-15-2001 08:00 PM
