08-29-2007
Originally Posted by arbarnhart
I have come up with an alternative to the rubber feet. I will use a backing plate that extends to below the bottom brackets and attach them to the backing plate. If I epoxy the backing plate to the hull, I feel really confidant that just having through bolts at the top will be sufficient.
Ummm... you do realize that the backing plate goes INSIDE the hull, and acts to spread the load of the bolts out over a larger area of the hull than would otherwise be the case, right???
By definition—if you're epoxying a plate to the outside of the hull—it isn't a backing plate. While your idea of using a mounting plate to attach all the mounting points to and then epoxying it to the hull is a good one, you still need a backing plate for the top bolts—the larger the better.
I think I will be okay without extras. I used a regular ladder at the transom to test and my smallest child could get over the transom from the step that was at just about the same height as the swim ladder top step.
I think his point was more that if the ladder doesn't extend down into the water enough, it will be very, very difficult for you to use it to climb aboard from the water. You generally need to have a minimum of two rungs of the ladder below the water's surface in order for you to get your feet on the bottom rung and climb back aboard.
