08-30-2007
An axe would take it down quite nicely...  What do you mean by the top of the mast is not weighted down???
If the mast is deck-stepped, and doesn't go through the cabin top, then it should be relatively easy to unstep the mast. If the mast is keel stepped, it gets more complicated.
