Blogs
User Name
Old 08-29-2007
landlockvasailor's Avatar
landlockvasailor landlockvasailor is offline
landlockvasailor is on a distinguished road
Hunt for Marine Plywood
I am sure that marine plywood can be found in the Hampton Roads area, but I won't be there for another month. Right now I am refiting a small O'Day and in need of Could someone in the Research Triangle area, Greensboro NC or southern Virignia give me a lead before I start running the net. L
Lewes, Home Depot can special order if I can use six or more sheet (which I don't understand, evey nail driver needs a sheet of MP I need only two sheets of 3/8"
Thanks
Tom
http://landlockedvasailor.blogspot.com/
Old 08-29-2007
Rockter Rockter is offline
Rockter is on a distinguished road
Buy the best. Dutch and Israeli stuff I have found to be best. Avoid hardware store stuff.
Old 08-29-2007
danjarch's Avatar
danjarch danjarch is offline
Boat less in Texas
danjarch is on a distinguished road
Home depot and lowes are retail outlets that cary some wood. You need to let your finger do the walking and call the lumber yards and contractor suply houses in your area.
!! WARNING !! The above information is to be used by intelligent people only. If you are Stupid, could be considered a moron, or otherwise. You are instructed to disregard this information and seek the help of a licensed and bonded professional.
Old 08-29-2007
Get the best though. It takes so long to fit out the ship, pay the extra for the best. It simply refused to delaminate if it's the best stuff.
Old 08-29-2007
rhaley rhaley is offline
rhaley is on a distinguished road
These guys are in Windsor NC. I have never used them personally, but I have heard good things about them. Good luck!
http://www.worldpanel.com/index.htm
Old 08-29-2007
Thanks for the Windor lead
Thanks, I will contact tomorrow
Tom
Old 08-29-2007
RickLaPaz's Avatar
RickLaPaz RickLaPaz is offline
RickLaPaz is on a distinguished road
From what I recall from my lumber sales experience years ago, the only difference between marine ply and exterior ply-(and also interior ply) was that it had a garanteed no void core. Which means there are no hollow spots within the core veneers. As far as I know the glue used was the same. Actually, according to my most recent supplier, even the newer interior plywoods have exterior glue. Your choice may depend on what you're using it for. Just remember, if you put enough epoxy and varnish on a peanut butter-jelly sandwich, it will still stand up to the elements. But if you require the most in a construction/structural project, choose, buy and build accordingly.
You also may want to peruse this for specs/apps. Caution, it's a bit wordy. Good luck...........
http://www.apawood.org/
Old 08-29-2007
arbarnhart's Avatar
arbarnhart arbarnhart is offline
arbarnhart is on a distinguished road
You might try Capitol City Lumber in Raleigh. They only list 1/4 and 1/2 on the web site:
http://www.capitolcitylumber.com/plywood.cfm
but it is probably worth calling them. Very cool yard to visit; you will feel like you stepped back in time.
Old 08-29-2007
Sailormann Sailormann is offline
Here .. Pull this
Sailormann will become famous soon enough
Marine Plywood is supposed to be put together with actual resorcinol glue - purple in colour and more expensive than epoxy...
Old 08-29-2007
RickLaPaz's Avatar
http://www.dap.com/docs/tech/00030205.pdf
Display Modes
vB code is On
What's the best way to epoxy in plywood? duffer1960 Gear & Maintenance 8 05-29-2006 06:34 PM
Marine plywood VS. pressure treated (wolmanized) plywood duffer1960 Gear & Maintenance 8 03-03-2006 12:12 AM
Marine Grade Plywood? Vastbinder General Discussion (sailing related) 42 07-13-2005 08:37 AM
Building Rudder/Sealing Marine Plywood mauidan15 Gear & Maintenance 8 04-18-2003 04:47 AM
Plywood replacement Gene4er Gear & Maintenance 0 10-29-2002 05:41 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
