Old 08-30-2007
mfeene01 is on a distinguished road
Fountaine Pajot cockpit door
I have a 1994 FP Tobago-35. The sliding door between the salon & cockpit is becoming difficult to open and close. It sounds like whatever roller/slider mechanism that is on the bottom of the door is wearing out (tends to grate & sounds like bare metal on metal).
I tried to remove the door for repair by taking off the top of the frame but, after I pulled all of the screws the frame top piece would not budge (even after a couple of hammer whacks).
Does anyone know how I can get the door out to repair it?
Any help would be greatly appreciated.
Thanks
Mike F.
Old 08-30-2007
Mike-
Can you post photos?? also have you tried to contact FP??
Old 08-30-2007
Libellula is on a distinguished road
You may try to turn the adjustment screws on the inside jam of the door. This brings the roller mechanism into the frame and when both top and bottom are adjusted all the way up, the door will lift out.
Old 08-31-2007
Cockpit door
Libellula,
The door does not have adjusters on it, it is a solid sheet of plexiglass that sits in a slot on the bottom frame piece. I have made contact with FP so maybe something will come from that.
Thanks for the suggestion.
Mike F.
Old 08-31-2007
please post the solution
Fountaine Pajot catamarans ireaney General Discussion (sailing related) 1 10-07-2004 07:32 AM
The Cruising Cockpit Sue & Larry Buying a Boat Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Gear and Maintenance Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Cruising Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Her Sailnet Articles 0 07-08-2003 08:00 PM
