08-30-2007
Another source of stench is the hoses... if you take a few hand towels and soak then in really hot water and wrap them around the hoses, and then take them off when they've cooled down a bit.. and sniff... any that smell nasty indicate that the hose they came from has been permeated by sewage and is probably a likely source of smell, and in need of replacement.
Sealand's OdorSafe hose is generally recommended as the best hose to use for a head's sewage lines.
Originally, I thought this should be in the off-topic thread... since it was SailHog asking about head problems... but it isn't a psychological thread this time around...
