08-30-2007
Do you need "Pathfinder" parts, or do you need VW parts?
Things like the heat exchanger boots are available elsewhere (perkins), RW impellers from Jabsco or Sherwood or aftermarket suppliers depending on your pump type.
The FWC pump is a standard VW part, as are oil filters, any engine items like injectors, bosch fuel pump, starters, alternators can all be found at any supplier for VW parts.
Pathfinder is on the web but a bit hard to find... I'll look for the link when I get home.
