08-30-2007
ASA and PSIA Instructor
Sea Tiger
I have one of these babies, usually just referred to as a Sea Tiger. As Cam said, you can find the manual online, her eis the link http://en.lewmar.com/support/PDF/S-L...er-D1031-1.pdf
As to parts good luck with Lewmar, when I called then years ago they just referred me to a disributor in NY whose name I forget, but you can sart with Lewmar...
FWIW I think the gearing in the unit is inherently stiff, did you try to operate it by hand or with the handle? Although ours is stiff, when you are cranking on the handle with a good load on it, you don't notice the stiffness anymore...works like a charm.
