How much of a propane smell? - Page 3 - SailNet Community
post #21 of 35 Old 08-31-2007
Señor Member
TrueBlue's Avatar
A handheld is good for detecting leaks BEFORE igniting a burner - but, doesn't do much good during the 8 hours your familiy's asleep on board.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #22 of 35 Old 08-31-2007
teshannon's Avatar
Chris,
They look like they might help in finding the leak but not for monitoring for the presence of propane.
teshannon is offline
post #23 of 35 Old 08-31-2007
teshannon's Avatar
What is the best location for a propane detector sensor? In the tank locker, near the oven, control panel etc?
post #24 of 35 Old 08-31-2007
If you install a gage right at the tank, then close the valve at the tank. You can over time (12 hours) deturman if the system is leaking.
jim colbert is offline
post #25 of 35 Old 08-31-2007
Freesail99's Avatar
Where is a good place or the best place to install a propane locker ? I have a rail stern mount for one tank.
S/V Scheherazade
Freesail99 is offline
post #26 of 35 Old 08-31-2007
teshannon's Avatar
Freesail99,
I have a tank locker in the cockpit. I was wondering where you route the sensor to from a detector?
post #27 of 35 Old 08-31-2007
Freesail99's Avatar
I read somehwere you don't want the detector to close to the source, or you get to many false readings.
S/V Scheherazade
post #28 of 35 Old 08-31-2007
Courtney the Dancer
jrd22's Avatar
Teshannon- we have two sensors, one is in the engine compartment/bilge and the other is in an empty space beneath the galley stove. You want to locate them as low as possible and below the appliances that use propane.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is online now
post #29 of 35 Old 08-31-2007
teshannon's Avatar
Thanks all for your input, much appreciated.
post #30 of 35 Old 08-31-2007
Generally, low in the cabin, but not near the oven, since lighting the oven generally releases a tiny bit of unburned propane. The real purpose of a propane detector is to warn you when levels of propane are building in the cabin or bilge of the boat... rather than to detect a leak per se.
sailingdog is offline
Propane Cabin Heater Mysun Gear & Maintenance 9 06-07-2009 11:29 PM
Wondering about where to put propane sensors... Sailormann Gear & Maintenance 5 05-14-2007 11:58 PM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 08:00 PM
That Diesel Smell Mark Matthews Gear and Maintenance Articles 0 08-27-2001 08:00 PM
From Propane to Butane John Kretschmer Gear and Maintenance Articles 0 09-23-1999 08:00 PM
