How much of a propane smell? - Page 4 - SailNet Community
post #31 of 35 Old 09-01-2007
teshannon's Avatar
Sailingdog,
Thanks. It sounds like the bilge near the stove is the ideal place.
teshannon is offline
post #32 of 35 Old 09-01-2007
You can get strong odors called the "heavy ends" when you are near the end of a cylinder. You have a concentration of mercapten and other contaminates like moisture dirt etc. which you will smell in combustion. Were you at the end of a cylinder?
bushrat is offline
post #33 of 35 Old 09-02-2007 Thread Starter
I'd rather be sailing
labatt's Avatar
After much reflection (and smelling and second opinions) we don't think it is raw propane we're smelling. It's got a very similar smell, but is a bit sweeter. We're almost out on the tank, so perhaps bushrat's idea is correct.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
labatt is offline
post #34 of 35 Old 09-02-2007
It would still be wise to check the system for leaks. Of course, if you're pretty sure it is the end of the tank causing the odor, you could try operating the stove from a full tank. If you don't get the smell with a full tank, it is probably the end-of-the-tank issue that bushrat mentioned.
sailingdog is offline
post #35 of 35 Old 09-02-2007 Thread Starter
labatt's Avatar
We'll still be doing the trace.. better safe than sorry...
labatt is offline
Propane Cabin Heater Mysun Gear & Maintenance 9 06-08-2009 12:29 AM
Wondering about where to put propane sensors... Sailormann Gear & Maintenance 5 05-15-2007 12:58 AM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 09:00 PM
That Diesel Smell Mark Matthews Gear and Maintenance Articles 0 08-27-2001 09:00 PM
From Propane to Butane John Kretschmer Gear and Maintenance Articles 0 09-23-1999 09:00 PM
