Old 08-31-2007
groundhog is on a distinguished road
diesel mechanic needed..
Looking for the name of a good diesel mechanic in the Baltimore-Annapolis Maryland area.
I have a volvo MD6A.
Thanks,
gh
Old 08-31-2007
Rockter will become famous soon enough
What's the problem with it Groundhog?
Old 08-31-2007
OK, you asked for it................. here's the long story........
Black smoke and char lilly pads shoot out the back on any kind of throttle up. Low engine output.
Cleaned or changed all filters in fuel line.
Rebuilt injectors.
Checked compression. ok. Pretty good actually.
Checked timing. ok as far as I can tell.
Cleaned out the tank. New gas from a highly traffic'd truck stop.
The above was all done at the end of last summer.
I had no knotmeter or rpm gauge last year. Now I have a knotmeter.
The engine did perk up after all that. I was able to go from a waddle (1knot?), to actually making a little wake (3 knots?) at full engine output. The engine output stops at 1/4 to 1/2 throttle on, and the black smoke starts.
Now the engine is overheating too, as we discussed in the other post.
The engine output has again dropped to where the boat waddles. 1-1.5 knots with knotmeter. 2knots top with smoke/char starting. 1 knot or lower with proper temperature. Above that it wants to be at 100C.
One guy I talked to last week told me to check the prop for barnacles. Sounds like a good idea which I will probably do today. I am hopefull about this idea, as I can see how it could explain a lot of what has happened so far. Had boat pulled and cleaned in June.
Also today I will put in the baracle buster in the engine.
groundhog
Old 08-31-2007
That's the problem..you're putting gasoline in a diesel engine...
Rebuilt injectors.
groundhog
Old 08-31-2007
What were your compression readings?
Black smoke is normally indicative of over-rich injection.
What did you mean by "timing"?
Old 08-31-2007
I think I remember getting like 350 lbf/in2.
Timing.. I checked the flywheel mark, checked the location of the piston with a coat hanger in the injector hole. It was comming just to the top when the marks crossed as the manual said. I got a visual on the injector squirt I believe. The injector was out but connected to the pump.
Think that's how i did it.
gh
Old 08-31-2007
teshannon's Avatar
teshannon has a spectacular aura about teshannon has a spectacular aura about teshannon has a spectacular aura about
chris oliver of Portside Marine in Annapolis is an excellent mechanic. He's just outside Bert Jabins Yard. He did excellent work on my boat.
Old 08-31-2007
To adjust the timing while the engine is running, I think you loosten the bosch injector pump mount screws and twist it back anf fourth. But When I went to do it, I think the pump was already set as far as it could go to one side.
gh
Old 08-31-2007
Tshannon, that's funny. He's the guy that told me to look for the barnacles on the prop.
Does he actually work on engines or does he just survey them?
gh
Old 08-31-2007
k1vsk will become famous soon enough
I assume you checked the exhaust elbow?
Diesel Mechanic in NC mhfowle Gear & Maintenance 2 10-24-2006 08:24 PM
Brooklyn diesel mechanic Mikenovit Gear & Maintenance 4 09-29-2006 08:03 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Need a Diesel Mechanic In Newport hamiam Gear & Maintenance 0 06-12-2001 12:25 PM
