Old 08-31-2007
SuzieWong is on a distinguished road
GPS connection to ICOM M802
Hi,
there is an HF ICOM M802 installed on the boat which I bought used. I know it should show a position as there is a cable plugged into the unit which should provide GPS data. Anyway, that doesn't work and as I intend to buy a second backup GPS unit I want to make sure I'll do the right choice:
Any specific GPS unit recommended with NMEA0183 ver 3.01 outlet (coaxial cable). I am not fancy for a unit with moving map, just display of present position plus data transfer to HF unit required.
Or can I plug a GPS antenna straight into the HF unit?
Furthermore I have slight problems to get a audio signal out of the headphone outlet to plug into PC for HF Fax reception. I tried a normal headphone, but there is only a constant noise, no tones (not even when the tones are clearly audible through speaker). Any comments what could cause the problem?
Old 08-31-2007
The NMEA 0183 shouldn't be a COAX cable, since NMEA 0183 is a serial connection. Last I checked, you need a GPS unit, or a GPS antenna that has an NMEA0183 output. BTW, a GPS antenna that has an NMEA0183 output is really just a GPS unit with no display or controls—pretty useless IMHO.
I would recommend you get one of the handhelds, that could be used in a life raft in an emergency, like the Garmin GPSMap 76C. This can run on AA batteries, but can also run off a DC power supply, via the NMEA 0183 cable.
As for the headphone jack, have you tried it with a regular set of headphones to see if it is functioning properly??
Handheld GPS Overview Tom Wood Seamanship Articles 0 05-31-2001 08:00 PM
GPS Gets More Accuracy Jim Sexton Seamanship Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Gear and Maintenance Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Cruising Articles 0 05-21-2000 08:00 PM
Advanced GPS Interfacing Jim Sexton Gear and Maintenance Articles 0 10-07-1999 08:00 PM
