Old 09-01-2007
SVDistantStar's Avatar
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
Beaching small sailboats.
Ive got 2 small sailboats that im thinking about beaching here soon to clean the bottoms on. One of them is a 1966 Columbia 24 and the other is a 1973 Oday 27. I know the Columbia is a full keel boat that can handle beaching, but im not sure about the Oday.
Im also thinking at the same time the Columbia is beached to check its thru-hulls and try to seal them off any way possible. It has taken on water in the past due to one of them having issues.
Any ideas for me?
Old 09-01-2007
danjarch's Avatar
Siren 17
danjarch will become famous soon enough
I wouldn't beach them to clean them. You can clean them in the water with a pressure washer and a hoka rig. You don't have to be certified to use a hoka.
!! WARNING !! The above information is to be used by intelligent people only. If you are Stupid, could be considered a moron, or otherwise. You are instructed to disregard this information and seek the help of a licensed and bonded professional.
Old 09-01-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
Hookah?
You might be able to get it done with a mask / snorkel and a scouring pad.
Other bottom cleaning ideas here:
http://www.sailnet.com/forums/showth...lean+bottom%22
http://www.sailnet.com/forums/gear-maintenance/31782-underwater-gear-hull-cleaning.html
Old 09-01-2007
'72 Pearson 36
Well both of them are anchored out, so no pressure washer around. Beaching just seems to be the easy answer since theres a nice little sandbar nearby. Beaching also gives me a chance to check out the thruhulls and try to figure out why the rudder is messed up on the Columbia.
Old 09-01-2007
Careening is a long, time-honored, way to clean the bottom of a boat. Careening differs from beaching in that the boat isn't run aground, but anchored in a spot that will have the tide leave the boat on the bottom and allow it to dry out.
Old 09-02-2007
Rockter will become famous soon enough
I certainly would not dismantle a through-hull between tides!!!!
Ablolutely not.
Old 09-02-2007
Tartan34C will become famous soon enough
Careening is when you haul a ship down on her side with a tackle from the masthead to a fixed point on the shore while the vessel is still floating. It was common at one time but not so safe with today’s small boats. You can still see large steel rings in some harbors imbedded in the stone wharfs that were used to anchor the tackle used during the days of sail.
Letting a boat dry out on a beach is usually fine and a great way to change a seacock or work on the bottom. I have done it with both full keel and fin keel boats with no problems at all. Just make sure the boat heels towards the shore so when the tide come in you start to float before you have water flowing into the cockpit.
Drying out alongside a dock is common in places like England but you need to be careful and this requires some experience before you try it. If you are new to this or don’t have someone experienced to help be careful because some boats are not a suitable candidate for this.
All the best,
Robert Gainer
Old 09-02-2007
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
If you care about your anti fouling paint (or the integrity of your hull, for that matter) you will never use a pressure washer to clean your hull underwater. Underwater pressure washing (or "jetting" as it is known in the biz) is best done with equipment designed for the purpose, and none of that kind of equipment is available at Home Depot, I can assure you. Further, regardless of what you use to pressure wash your boat's bottom underwater, the resistance of the surrounding water will require that you have to get the washer tip so close to the hull that you will literally blast your anti fouling off the boat. If you are not careful you can actually damage the hull, as well.
BTW, you don't have to be certified to dive with SCUBA gear, either. But anybody breathing compressed air underwater (be it from SCUBA or a hookah) should understand the dangers involved. You could injure or kill yourself even at the depths required to do hull cleaning.
"Clean bottoms are FastBottoms"
Old 12-22-2008
tager's Avatar
tager is on a distinguished road
Ablolutely not.
Why not? Some tides would provide you with a little less than 24 hours of dry-time. If you can't fix a through-hull that fast, you have bigger problems than a sunk boat.
Just come prepared, and ignore the naysayers.
Old 12-22-2008
camaraderie's Avatar
moderate?
24 hours? Where might that be? Dead low to high tide is 6 hours or so here and most places on earth.
electric trolling motors for small sailboats? thebrakes General Discussion (sailing related) 18 07-25-2010 01:29 PM
small rooftop sailboats crashtom Learning to Sail 18 01-09-2009 10:05 AM
small sailboats sailingforever Boat Review and Purchase Forum 7 12-23-2008 09:54 PM
Small Boat Cruising David Schaefer Cruising Articles 0 06-09-2004 08:00 PM
Good small cruising sailboats? Jeffamc Cruising & Liveaboard Forum 2 08-19-2003 05:19 AM
