Old 09-01-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
Pressure Washing
I've never used a pressure washer on my boat, hull or topsides. I use non abrasive cleaners and fairly soft brushes. I don't like the thought of using high pressure water on the gel coat or pushing water in under fittings on the deck.
I'm averse to using a pressure washer to clean the bottom. My thinking is that I've applied Interlux to avoid osmotic blisters due to a few psi of water pressure, hitting the hull with several hundred psi of water pressure can't be good.
Has anyone seen / heard of water intrusion problems, gel coat damage or osmotic blisters from pressure washing or am I just being paranoid?
Old 09-01-2007
camaraderie's Avatar
moderate?
Paranoid if you are talking about the hull. Moderate pressure washing is perfectly fine. On deck it can loosen bedding compound and cause intrusion.
Old 09-01-2007
k1vsk will become famous soon enough
Confined to the hull and deck non-skid, low pressure pressure washing works great at removing dirt from the non-skid resesses and is pretty commonly used on both with no problem
Old 09-01-2007
Rockter will become famous soon enough
Superb at cleaning teak, as long as you set the nozzle to "fan" pattern, and stand back a fair bit, say 9".
The green soup muck floods off the old ship.
It is far easier than scrubbing, and faster.
Just be careful with it.
Breadmaker aboard CHRISTINE-R Provisioning 21 08-14-2006 11:43 PM
W60 - No oil pressure after oil change??? pma_foyl Gear & Maintenance 9 12-01-2004 09:45 AM
Oil Pressure Problems Tom Wood Gear and Maintenance Articles 0 05-16-2002 08:00 PM
Cooking Under Pressure Kathy Barron Gear and Maintenance Articles 0 10-20-2000 08:00 PM
Cooking Under Pressure Kathy Barron Her Sailnet Articles 0 10-20-2000 08:00 PM
