JEFF_H HELP - SailNet Community
Blogs
Old 03-22-2002
KIKO is on a distinguished road
JEFF_H HELP
Jeff,
Please help me with this one.
I''ve almost been hit (ant to that matter my small son, too) by a speeding boom, when downwind. Fortunetely no harm done!! (so far).
A friend told me to get a boom brake or boom "spring" that helps keep the boom steady, depending on tension.
Does it work !!
Please
Old 03-22-2002
Jeff_H's Avatar
Super Moderator
JEFF_H HELP
I have never used a boom brake or been on a boat that did. I understand they work well. When cruising or daysailing, I personally try not to go dead downwind finding that broad reaching yields a more comfortable motion, better VMG, and has a greater margin of safety. As a helmsman, when sailing deep, I especially try to come up slightly onto a higher point of sail when people are moving around the deck.
For long close to downwind passages, I rig preventors on both sides of the boat lead from the end of the boom to a turning block close to the bow and then back to the cockpit. I use a light stretchy line of this purpose so as to no strain anything in an accidental jibe.
Old 03-23-2002
JohnDrake is on a distinguished road
JEFF_H HELP
The "Boom Brake" is made by Dutchman and can be found in just about every major boating store for about $300. They are very easy to install.
I agree with Jeff about sailing downwind and while a preventer is the choice of many sailors, I don''t really like them, in some situations. To rig a preventer, you have to go up on deck (sometimes this is not desireable) and, in confused wind situations, they may need a lot of attention. Once, a friend was using one and it whipped back and forth and cracked the glass in one of his ports.
If I were to get something, I think I would try the Boom Brake first.
Hope this helps.
Old 03-23-2002
JEFF_H HELP
Thank you both.
I''m going to try that next Monday.
Will let you know
KI KO
Old 03-23-2002
JEFF_H HELP
I found a similar boom brake.
Boom Stay, page 83 March 2002 Sail magazine.
AK
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
