Vertical slide motor bracket? - Page 2 - SailNet Community
post #11 of 13 Old 01-20-2009
resdog's Avatar
Did I say I love Google?
Here's a shot of the outboard mount I was referring to:
I think the old mounting system had a 6:1 lifting arrangement and the new one is 12:1. I think general Boats also are using a better bearing assy.
resdog is offline
post #12 of 13 Old 06-22-2009
Have you found the motoro mount?
Mundi,
I know this thread is old -did you find the motor mount you were looking for
I'm looking for the same thing. I've seen other styles -but haven't found any yet.
Thanks
Roguebear is offline
post #13 of 13 Old 08-26-2009
Hello John and others
I am looking for an easily removable hanging vertical slide outboard motor mount for a Nicholson 32 to be used to mount 5 hp engine for getting into a marina. It will need two horizontal struts at bottom with bumpers to push against transom. I expect to mount it to a wooden block bolted through the rear deck. I assume I will end up with some kind of welded steel tube design.
I do have a diesel engine but do not lke to rely on it.
Maybe I should just get a long sculling oar?
I would like to know how it worked out for you or other . Thanks
Pasquale is offline
Tuning Vertical Dipoles the Easy Way btrayfors Gear & Maintenance 5 04-29-2007 06:55 PM
The Magazine Slide (The Motley Fool via Yahoo! News) NewsReader News Feeds 0 12-05-2006 03:15 PM
Windlass - Horizontal or Vertical? PBzeer Gear & Maintenance 8 03-03-2006 05:51 AM
Types of Mainsail Vertical Furlers flicker Boat Review and Purchase Forum 0 10-24-2003 05:13 PM
Strong mainsail slide system clayton Gear & Maintenance 3 06-12-2002 06:32 PM
