-   -   Vertical slide motor bracket? (http://www.sailnet.com/forums/gear-maintenance/36585-vertical-slide-motor-bracket.html)
mundi 09-04-2007 10:08 PM
Hi,
I'm trying to mount an 8 hp, 2-stroke Tohatsu outboard on my transom. The boat is a Catri 24 folding trimaran. The rudder has a horizontal hydrofoil, and the rudder can kickup if it hits an obstruction. It that happened, the hydrofoil would get eaten by the prop with a standard motor bracket, such as those by Garelick or Fulton.
I want to find a vertically sliding motor bracket, not the parallel-o-gram type that swings *back* when it is put in the down position.
Does anyone know of a vertical sliding motor bracket?
Thanks,
/John
CapnHand 09-04-2007 10:18 PM
Just a thought; can you mount the outboard somewhere else, like on one of the amas, that would put it out of the way of the rudder / foil?
sailingdog 09-04-2007 11:15 PM
As a trimaran sailor, one of the few here, I think you'd be better off not mounting the motor on the transom. A transom mounted motor is going to have more problems with cavitation and not staying submerged due to the motion of the boat. I would recommend that you mount it on a sled, attached to the side of the main hull of the ama crossbeam if at all possible.
If you have questions, let me know.
mundi 10-08-2008 03:47 PM
Thanks SailingDog and CapnHand.
Wouldn't the sled have the same issues of not staying submerged?
I'd have to check to see if the folding action would permit such a sled. I fold prior to docking in my slip.
mundi 10-08-2008 03:54 PM
Hey Leonard,
I did not find any commercial products that fit my needs, so DIY is the way to go. I found two other boats that had photos of sliding mounts, of which I only kept one photo. However, it is a horizontal slide on a boat with no transom, not quite the right thing.
s309.photobucket.com/albums/kk396/torrmundi/?action=view&current=F-boatCheekeeMonkeyslidingmotormoun.jpg
You certainly can use sail tracks and cars, such as those from Harken or Ronstan. But that is pretty expensive. Or you could make a custom stainless tubing design with nylon slides. I'm not sure if that would actually be any cheaper!
Either way, you probably want to include stainless steel springs to reduce the gravity load. It should also include a locking feature to keep the motor in the up or down position. A pin through the track may work for some installations, but not mine. I can't easily reach back and down over the stern. A rope system with clam cleats might also work.
Please tell me if you make any progress on this - I've not yet made a workable solution. Here's my transom, with my current engine mount upon the rudder.
s309.photobucket.com/albums/kk396/torrmundi/?action=view&current=TransomDetails03.jpg
Note that if I use a standard mount like this:
s309.photobucket.com/albums/kk396/torrmundi/?action=view&current=Mount.gif
then the action swings the engine out away from the transom in the operating position and if my rudder then kicks up, the horizontal foil with get chewed by the prop. That's why I need a vertical track arrangement.
/John
ps - I don't have the account type that allows PM's, so I'm posting this as a thread reply. The photos are viewable by pasting the links into your browser. I don't have enough Sailnet posts to enable hyperlinks yet.
Originally Posted by cal30
Howzit Mundi,
Just wondering if you ever came across a sliding bracket for your outboard. Looking for the same type set-up for my boat (vertical or up/down movement). Please if you had any luck or know more let me know. Pics would be a help too. We have someone that could manufature a mount, but need some ideas.
Mahalo,
Leonard
mundi 10-08-2008 04:25 PM
I forgot this device by Plastimo - it is a vertical slide, but won't work for me due to the depth of the device. I'm not sure the vertical travel is enough, either, but they have two rail lengths: 400mm and 600mm. It is model number 17619.
Go to plastimo.com, and select Power Boating > Motor Brackets > Standard Motor Bracket
/Mundi
resdog 10-09-2008 05:49 PM
I know exactly what you're talking about. A gentleman at my marina has one on a Rhodes that slides up and down vertically. The mount is big and bulky and very ugly if you ask me. But I will see if I can find out the mfg this weekend.
sailingdog 10-14-2008 11:36 AM
An outboard sled or bucket generally doesn't have the cavitation problems of a transom mounted outboard for two reasons. One, it isn't as far aft...so it doesn't rise and drop as far as the transom mounted ones do. Two, the bucket or sled will usually allow the engine to drop down further into the water than a transom mount generally will, and as such will help keep the prop submersed.
mdi 01-15-2009 04:08 PM
Vertical Engine Slide
Where you able to locate the information for the slide you referred too? If so please contact me with the information.
Thanks,
Pat Ross
resdog 01-20-2009 12:04 PM
Thanks,
Pat Ross
I looked all over that mount for a mfg's mark and found nothing. It may be something that Rhodes builds. I'll see the owner this weekend and ask him if he installed it or if it came with the boat. You might try doing a search on Rhodes 22. Maybe it will show up.
I did a little searching and found out the mfg of the Rhodes 22 is General Boat in N. Carolina. Here are a couple of links to the outboard mount.
http://www.rhodes22.com/contacting_g...ats_small.html
General Boats
give GB a call
