09-05-2007
IF the alternator is working and you have a voltage regulator, you should be getting at least 13.4 VDC off of the electrical system.
If your shore power charger is working and plugged in, you should also get at least 13.4 VDC off the electrical system.
If your batteries are reading under 12 VDC, then they're not anywhere close to being fully charged and in need of charging, which likely means the shore power charger isn't working.
