Old 09-05-2007
chuckg5's Avatar
chuckg5 is on a distinguished road
Question Scratchy compass face
The compass on top of the binnacle is a 5" danforth 'constellation'.
Sitting at the wheel , looking forward, I can see the degree numbers but its a little scratchy an foggy. on the forward part of the 'globe' it is clear.
Can I loose up the philips head screws on the collar of the globe an turn it
180 degrees?? I'm guessing a lot of oil will come out but I can replace that.
the oil I'm guessing might be mineral oil.
Old 09-05-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
Mineral oil is no longer used, or so I was told. There are 2 different oils currently being used. A compass repair place would also have new "faces" for your compass. I got great service from these people http://www.islandcompass.com/repair_&_adjusting.htm
S/V Scheherazade
Old 09-05-2007
chuckg5's Avatar
thanks, I just went to Vicking Optics on the net and they have all the
replacement parts for Richie an Danforth. I'll check out the other link too!
I'll probably try an rotate the globe anyway, at least now I know where to go for parts!
Old 09-05-2007
Freesail99's Avatar
There will be a gasket you'll need to replace once you open it.
S/V Scheherazade
Old 09-05-2007
Rockter will become famous soon enough
Toothpaste !!!
Old 09-05-2007
chuckg5's Avatar
I'll break down an get a gasket an a quart of compass oil.
toothpaste, gotta remember that if I ever blow a head gasket in the middle of davy jones's relm
Old 09-05-2007
NO, use it to polish the surface.
Old 09-05-2007
chuckg5's Avatar
ohhhhhh, I'll try that first
Old 09-05-2007
Lancer28's Avatar
I'm the FNG still...
Lancer28 is on a distinguished road
I went from this to this on my compass:
My boat sat for FOURTEEN YEARS in the sun, rain and snow before I got my hands on it.
It's quite simple actually. Get a low speed power drill with a cloth buffer pad on it. Then use the Turtle Wax Rubbing Compound on it (and keep it wet with compound) for about 5 minutes. Go over it with a new pad and carnuba wax for about 5 more minutes to finish it. (the photo where it is clean is BEFORE the carnuba wax application)
Wipe dry and you're set. I've used this on everything from motorcycle restorations to car headlights. USE ONLY MICROFIBER CLOTHS, and use LOW LOW LOW SPEED!!!
Old 09-06-2007
chuckg5's Avatar
Wow, Lancer
nice job
mine's nowhere near that bad, but yours looks good as new
this is the way to go
Understanding and Using the Magnetic Compass Jim Sexton Learning to Sail Articles 0 03-01-2000 07:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Seamanship Articles 0 03-01-2000 07:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Gear and Maintenance Articles 0 03-01-2000 07:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Cruising Articles 0 03-01-2000 07:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Her Sailnet Articles 0 03-01-2000 07:00 PM
