09-06-2007
humble pie rat
Unless your boat has a problem starting.....
That's just it, do you always know if you're going to have a problem starting? Of course not, which is why I prefer to keep the starting battery fully charged.
By having the alternator connected to the house bank, you keep them more fully charged than by connecting it to the starting bank. Also, there really isn't and delay in charging the starting battery, since the ACR will combine the banks within in minute of the alternator going on or so if it is configured properly.
There is minimal current draw from the relay (<0.2A) when its closed so if the last statement is true, then the statement preceding it must be false.
Is the last statement true? From the factory, my ACR was set to combine at 13.5V. Charging volts won't get there until the batteries are ~85% charged. So, unless there is a very small house bank, or a very large alternator, it could take some time (several hours) to get the house bank 85% charged to where the ACR would parallel the batteries and charge the starting battery.
Configured properly; how is that, exactly?
