Old 09-06-2007
avazquez's Avatar
avazquez is on a distinguished road
Fuel Supply Line...
Should the engine and the generator have separate fuel supply lines? Can they share the same diesel supply line?
Old 09-06-2007
Pamlicotraveler's Avatar
Pamlicotraveler is on a distinguished road
Our generator has a separate supply line and does not pass through the primary fuel filter. It draws from one specific fuel tank. I would think two engines pulling from the same line could require more fuel than one supply line could take if they were running at the same time.
The next best thing
To playing and winning is playing and losing.
Robert Lee Castleman
Old 09-06-2007
avazquez's Avatar
So you have two separate diesel tanks?
Old 09-06-2007
I would have separate lines for each.
Old 09-06-2007
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
It would depend on the requirements of the 2 motors. Size of line and line pressure. But the easy way out without doing the math, run 2 lines and be safe.
Old 09-06-2007
Rockter will become famous soon enough
You could branch off the line, I reckon. But remember that a leak on either one will stop then both. A pressurised fuel line would avoid that, I am sure.
A separate fuel line may not be easy to fit. It normally means drilling another hole in the top of the tank, and that is not always easy either.
If you do drill another hole, put a wee bowl in the tank beneath the hole you are drilling with a wee bit of water in the bowl to douse the heat of the drilling swarf. Let's not take any more fire risk that we have to.
Never try that on a gasoline tank.
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Getting Good Starts, Part Two Zack Leonard Racing Articles 0 01-15-2004 07:00 PM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
