Old 09-06-2007
Julie303 is on a distinguished road
Question gas:oil ratio for 1949 5 hp sea king 2-cycle twin outboard
Does anyone know what the proper gasil mixture should be for a 1949 5-HP Sea King 2-cycle outboard motor?
Old 09-06-2007
SVDistantStar's Avatar
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
50:1 will work just fine in it.
Old 09-06-2007
ebs001's Avatar
ebs001 is on a distinguished road
All older motors that I can recall from the 50's, the recommended ratio was 25:1
Old 09-06-2007
Rockter will become famous soon enough
Not 50:1 for a 1949 motor. Not so.
Very few modern motors get by on that. I know of only one... the MZ 301 motorcycle.
Run rich for an old motor... 25:1 or even 20:1.... it'll smoke like crazy though.
The problem is that the old ball and roller bearings were quite sloppy, and needed alot of oil to float them. Quality is no substitute for quantity in those old bearings.
Old 09-06-2007
capngregg's Avatar
Shaken-not Stirred
capngregg is on a distinguished road
Cool
I got the information below from another on-line forum but it is what I run in my 1945 Gale Manufacturing motor. They have flat bearings in the mains and rods. Gale Mfg. / Sea King sold by Montgomery Wards.
You can mix modern unleaded gas 24:1 with TCW3 rated 2 cycle marine oil and you should be fine. (This was for a 1951 version of the same motor)
Manuals are hard to come by but they're out there. Same with the parts.
Good Luck! That's a nice little motor.
Opportunity is missed by most people because it is dressed in overalls and looks like work.
T.A.E.
Old 09-06-2007
'72 Pearson 36
I would have figured 50:1 would work fine. We use 50:1 in a 50's Evinrude 18hp motor that we have.
Old 09-06-2007
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Capngregg mentions "modern unleaded gas" - a similar question I was meaning to ask is:
We have a choice of 91-, 95- and 98-octane unleaded depending upon how empty you want your pocket when you pay up at the till..
Is there any difference when mixed for a 2-stroke??
Old 09-06-2007
Lancer28's Avatar
I'm the FNG still...
Lancer28 is on a distinguished road
That motor won't benefit from higher octane; stick to the minimums.
Old 09-06-2007
Hartley18's Avatar
Termite Fodder
Thanks - I assume that holds true for modern-ish Johnsons also.
BTW: Did you manage to locate any electrical data on my 7.5hp? I'm still at a loss to know what to do there...
Thanks in advance,
Cameron
In Search of Sea Room Micca Hutchins Seamanship Articles 0 03-26-2002 07:00 PM
Sea Snakes Ralph Doolin Seamanship Articles 0 01-21-2002 07:00 PM
Sea Snakes Ralph Doolin Cruising Articles 0 01-21-2002 07:00 PM
