-   -   Raise mast on 21 macgregor (http://www.sailnet.com/forums/gear-maintenance/3665-raise-mast-21-macgregor.html)
sach 03-24-2002 07:53 PM
I have a gin pole to raise the mast on my 21 ft macgregor.I saw a mast raised on a 21 ft macgregor with a line on each side of the mast leading port and starboard to keep the mast from swinging side to side while being raised by one person. Will someone please tell me how to rig this on my boat?? Thanks
goduke 03-28-2002 07:21 AM
Wouldn''t the upper shrouds provide that stability after you got the mast up high enough for it to become unruly? I don''t know much about a Mac''s rigging but this seems to be true of most smaller boats that have no backstay.
sach 03-28-2002 05:42 PM
This is true after the mast rises past about 50 degrees, assuming up is 90 degrees. I need to stop side motion those first 50 degrees raising it single handed.I do have a backstay.Thanks for your reply, I was starting to think I was still single handed.
Sfilson 03-29-2002 03:59 AM
We have a MAcGregor 22. I have seen the setup you are mentioning but never used it. I think what I saw was someone using a set of lines rigged under the spreaders to the chainplates. As long as they are inline with the mast step they shouldn''t need lengthend or shortend as the mast is raised. Also the guy showing me this bended a third line to the lines used as Temporary Shrounds to recover them once the mast was up.
It will take some practice to get it to work good on your boat. One of our problems is the standing rigging getting fetched up on other gear on the way up. It doesn''t seem to matter how careful we lay stuff out something will get hung. i.e. we usually have a problem with the shrouds getting cought under the "pop top" cabin top or the backstay around the mast crutch. It is always nice to have an extra hand to run around a clear this stuff.
Another small boat sailor who does mostly single handed sailing we know uses an extra long jib halyard to act as a temporary adjustable headstay as the mast goes up. With the temporary shrouds and using the Jib halyard you could let the mast go for a second and clear shrouds and the backstay. Don''t do this if your mast step doesn''t have a pin through the foot of the mast.
Scott
