Old 09-07-2007
Sea Slacker
brak is on a distinguished road
Dry-seal
I just bought the "dry-seal" made by Lasdrop to replace a previous dripless seal (of similar design). Basically this is a rubber seal type as the other one was. However one thing that surprized me is how tight the rubber gasket is - for a 1-1/8" shaft it is about 1" in diameter - and pretty hard to squeeze on it (though not impossible). The old seal was just tight enough, barely touching the shaft. I called the manufacturer and they claim that "its ok, it will be tight around the shaft", but I am still not convinced this is the right size. Those guys seem to be a bit careless about sizing (sent me 2" hose diameter for 1-7/8" stern tube and the answer to that is "it will tighten just fine with clamps").
So, any experience with these seals? Are they meant to be so tight? Wouldn't that cause the rubber seal to wear out?
Old 09-07-2007
Sea Slacker
Damn, guess those things are a mistery to you guys just like they are to me. Well, sure hope I won't be left with a hole in my boat.
Old 09-07-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
This is everything I know about seals.
Old 09-07-2007
Sea Slacker
Funny video ))))
Still doesn't help, though.
How to dry clothes at Sea? Traveling_Jim Cruising & Liveaboard Forum 12 04-22-2006 07:39 AM
Deisel Rear Main Seal pma_foyl Gear & Maintenance 1 06-22-2004 07:24 AM
Packless Shaft Seal (PSS) bkdehuff General Discussion (sailing related) 4 04-20-2004 05:41 PM
Using Dry Ice Sue & Larry Gear and Maintenance Articles 0 09-02-2001 08:00 PM
Discovering the Dry Tortugas Sue & Larry Cruising Articles 0 03-12-2000 07:00 PM
