09-09-2007
Rockter-
Given that the piece he's looking to build is an interior piece, not in the bilge, and he's planning to thoroughly coat it in epoxy... I don't think that delamination of the plywood will be an issue, especially if he uses an exterior grade of plywood, which uses a waterproof adhesive.
The primary difference between marine plywood and a good grade of exterior plywood is primarily the thinner plies used in the marine plywood, and the fact that marine plywood has no voids and fewer imperfections.
Given that... I don't see a problem with using a good grade of exterior plywood to make the berths.
