Old 03-25-2002
halyardz is on a distinguished road
Extra Batteries--Golf Cart?
A number of discussions about the main banks but I''m looking for a short term backup or alternative for lighting. Should one just carry a spare 12v deep cycle or go to the golf cart battery option?
Old 04-13-2002
Larrys Pal is on a distinguished road
Remember it takes two golf cart batteries (6 volt each) hooked together to make 12 volt. Space maybe a problem.
Old 04-13-2002
Pangaea is on a distinguished road
halyardz,
There is alot to be considered in choosing batterys for a boat. But in a nuttshell:
If your boat is smal,20 to 26 feet, and all you want to do is run interior lights, a grp 27 will most likly be all you need. Remember, try not to run your batterys down more than half way between charges and then don''t let them stay down, recharge imediatly or as soon as possible. If you are constantly running them down bellow 50% between charges, then your battery bank is to small.
Hope this helps.
Dennis
Old 04-13-2002
Thanks LP and Pangaea. I do have a separate starter and deep cycle for the house. Just looking for the best alternative for a separate battery to be recharged when on shore power. I''ve got plenty of space for the install. Sounds like just another deep cycle would do the trick.
Use of AGM/Glass mat batteries santorinidon Gear & Maintenance 7 07-15-2006 12:59 AM
Golf cart batteries hathanger Gear & Maintenance 8 03-13-2005 03:23 PM
Internal Regulation sjacovino Gear & Maintenance 31 04-05-2002 02:40 PM
6 Volt Batteries vs 12 Volt ABullard Gear & Maintenance 10 09-06-2001 05:41 PM
Batteries - Mixing Different Ah ken346 Gear & Maintenance 1 05-27-2001 11:59 AM
