09-11-2007
crack in cast aluminum
I had a ramp accident; my rudder dropped and I damaged it only slightly, but I cracked the cast alumiunum rudder housing. Here is a picture of one (not mine, but a handy photo):
The crack is close to the lower pintle. The housing is one piece of cast aluminum, so it is still attached at the top, quite heavily. I did not notice the crack until after I got home and I had sailed with it like that all day. Between still being solid at the top and the cleavis pin through the rudder holding it tight, there had been no problem. My thought is to work some thick epoxy into the crack. I could also drill through and bolt it if that were necessary. I will be securing my rudder in the up position using a better method (I was using a friction cleat) in the future. Anyway, what would you do?
-Andy
Newport 17 - "Kohanna"
At sea Darwin's hypotheses is the final arbiter of right of way.
