Old 09-12-2007
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Jackstands: Number And Size?
We'll soon be needing jackstands for our new-to-us Pearson P30. We're thinking of these: http://www.kleeco-marina-equipment.com/boatstands.asp
The question is: For our P30: What size and how many? A friend suggested six (6) of either the medium (MSBJ - 48-60") or large (LSBJ - 60-72"), the idea being four (4) in use and a "spare" pair to allow us to move one set at a time for bottom-painting. Then again: Another club member, with a 37' boat, is getting eight (8). So I don't know whether I should get six (4+2) or eight (6+2)?
Thoughts? Experiences?
Thanks,
Jim
s/v Abracadabra
1976 Pearson P30
Old 09-12-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Not familiar with Kleeco stands, but if they're similar to Brownell stands, here's a guide for sizing them to your boat : Boat stand sizing guide
True Blue . . .
sold the Nauticat
Old 09-12-2007
SEMIJim-
It really depends on the height of the blocking you're using to support the keel of the boat and where you're placing the stands. What is the draft of your boat, and what is the distance from the ground to the area the pads will be located.
Considering that the P30 has a draft of 5' or so, the use of medium stands is probably not such a good idea, since their adjustment range ends at 60". The large stands go from 60-72"... and if you use 8x8" blocks for the keel, you would probably have a decent range for supporting the boat, However, it depends on the hull shape quite a bit.
I would get seven or nine boat stands. One should be a v-shaped head for the bow. The others should be regular boat stands. A guideline I've been told is one pair for every 10' of LOA, plus a pair for use as supports to move the others... you could go with either six or eight... depending on what you feel comfortable with. Eight would be more secure.
Personally, I would recommend getting nine stands total.
Old 09-12-2007
saurav16's Avatar
saurav16 is on a distinguished road
Send a message via AIM to saurav16
I think for brownell stands you will need SB2's. To be really safe you can do 6 standard sb2's with and one with a v top. Therefore 7 jackstands.
Old 09-12-2007
vabuckeye's Avatar
vabuckeye will become famous soon enough vabuckeye will become famous soon enough
http://adcache.boattraderonline.com/6/0/4/89894304.htm
You might want to check this out. I count 6 stands and 2 sets of blocks on this 31 footer. This looks to be after the fall, so I would consider 9. You will never regret having too many, only too few.
Old 09-12-2007
TrueBlue's Avatar
Señor Member
vabuckeye,
From what I can tell from the before photo, the jackstand chains were not tightened securely. There appears to be considerable slack. Whether this boat had 7 or 9 stands, they do little good in a stiff wind if not chained together laterally.
True Blue . . .
sold the Nauticat
Old 09-12-2007
TrueBlue's Avatar
Señor Member
Actually, after looking closer it seems that the so-called "before" photo was taken after the fall - shorter powerboat stands were used, due to the broken keel.
The other pics show sailboat stands - difficult to say if the chains were secure or not - not enough evidence. I do agree though - never enough stands.
Curiously, this boat is just across the Bay from us.
True Blue . . .
sold the Nauticat
Old 09-12-2007
Actually, I think you mean nine...since he needs a spare set to use when he is painting the bottom, so he can move the ones that are actually supporting the boat around. I think you want him to have six stands and a v-top supporting the boat.
Old 09-12-2007
SEMIJim's Avatar
Thanks for the input, everybody.
Nine (four on each side and one on the bow) seems excessive to me. I'm thinking seven (three on each side and one on the bow) should do it. Brownell recommends one for every eight feet. That would be 3.75 for our 30' boat. So I think four per side, plus a bow stand, should do the trick.
I'll probably go with the large (60 - 72") ones. ISTM it'd be easier to add more blocking under the keel if the large are too tall, than to remove ground under it if the medium are too short . (Esp. in an asphalt parking lot.)
Btw: Is there some reason chain is used to lash these together, rather than steel cable?
Jim
s/v Abracadabra
1976 Pearson P30
Old 09-12-2007
SEMIJim-
You need nine stands.... three per side (six total), plus a bow v-stand and a spare pair for when you're painting.
Catalina, Beneteau, or What ? johnwalsh Boat Review and Purchase Forum 13 09-19-2004 05:25 AM
Size Matters Don Casey Buying a Boat Articles 0 04-05-2002 07:00 PM
