Old 09-14-2007
jimspafford is on a distinguished road
fiberglass repairs
it is time for me to start doing repairs on the hull and deck i have a few soft spots on the deck and pitting and cracks in the gel coat i have done fiber glass before but not on a sail boat but never applied any gel coat. i am looking for a book or a website or just some good advice
Old 09-14-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
Here are a Couple of quick links.
http://www.boatus.com/boattech/casey/17.htm
Some videos
http://video.google.com/videoplay?do...erglass+repair
http://www.youtube.com/watch?v=_yvPz_vQAjA
If you look around on Utube and the Johnsondistributor site there are a few more.
I hope this helps.
S/V Scheherazade
Old 09-14-2007
southerncross31 is on a distinguished road
I would recomend Don Casey's book...I think called sailboat hull and deck repair. I recored the cabintop on my boat. It isn't all that difficult to do. Making the end product look like the factory finish is the hard part. Find the perimeter of the wet area with a meter or by drilling holes. Make sure you find all of the wet area before you cut. I have seen too many people who don't want to make a huge hole in there boat so they start with a small one...then another, and another. In the end the cut out looks like a puzzle and it will be much harder to finish well! Find out the thickness of the outer skin and use a pencil to mark the cut out. You need about 3-4 inches of open space on both sides of the cut to bevel and fillet. Then set your skill saw to just over the thickness of the skin. Make the cut. Then use paint scrapers,prybars, chisels, heat gun......whatever you can to remove the outer skin without damaging it...you will reuse it later if it is still intact. This part is hard....there will be some sections of core still adhered to the skins. If you can't remove the outer skin w/o killing it, you can lay up a new one.
Using a wood chisel, carefully remove all of the core material from both skins (if the outer is still intact). Then wipe them down with acetone to remove any wax/oils. Then grind them with 60 grit untill there all fresh glass.
Fiberglass is NASTY stuff. I am not allergic to anything, but fiberglass dust makes me feel like i'm being attacked by fireants...especially if your sweating! Wear a while painting suit, with long sleeve shirt/pants under and get the best respirator you can find. They make a full face one for like 100$ (it's your life). Use a sander/grinder that can hook up to a rigid shop vac so most of the dust is sucked up.
I've got to go now but will finish later....P
Old 09-14-2007
thank you gentlemen the worst spot is at the bow i think the feller i bought the boat from let the anchor lay on the deck there maybe so maybe not but it just didn't seem like a good practise to me
Old 09-15-2007
Jim-
the likely culprit is hardware going through the deck. Is the soft area near the bow under or around a deck cleat or near the pulpit stancions... those are often points of water intrusion. It would be a good idea, if while repairing the soft areas, to remove the nearby deck hardware and re-bed it—properly potting the fastener holes in the process.
The legacy of Philip Rhodes GoodOldBoat Buying a Boat Articles 24 03-09-2012 04:06 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Effecting Fiberglass Repairs Mark Matthews Gear and Maintenance Articles 0 02-24-2002 07:00 PM
First Fiberglass Repair SailNet Gear and Maintenance Articles 0 09-01-2001 08:00 PM
