OH duh! (lost my water!) - Page 2 - SailNet Community
post #11 of 12 Old 09-16-2007
Denise, on starships the power is expected to be there all the time, so important things like life support and shields can operate, and if there's a power failure you've got big problems, it just ain't supposed to happen.
Sail diesel powered sailboats are built with a different philosophy in mind: That the electrical system can and will fail from time to time, from a dead battery if nothing else. And having a diesel engine that can be hand-cranked (in theory anyway) with fuel and water and oil pumps that all run off the reliable diesel engine, without electricity, is supposed to be a good idea.
So by all means, use an electric pump--if your electrical system is up to starship standards. [g]
hellosailor is offline
post #12 of 12 Old 09-17-2007 Thread Starter
One of None
deniseO30's Avatar
Fixed!
Went to this Marine supply in NJ not far from here. One if my club friends raves about it. I get there... one word.. OBERDORFER... deap pan look and reaction. He makes two calls to Fla for the part numbers. Turns out he actually had the parts back there! New plate, seal and the gaskets which are exstreamly thin on this pump. Between the worn old plate and homemade gaskets the pump wouldn't pump or hold a prime. It's working now.. better then ever I might add.
Again thank you all for you input!
My last project!
deniseO30 is offline
Atomic 4 - Water in Cylinders!!! wbgent Gear & Maintenance 27 03-15-2010 10:24 PM
Flushing/testing/preping an old water system on a new old boat tenuki Gear & Maintenance 8 04-19-2007 10:33 PM
Water, Precious Water Michael Carr Cruising Articles 0 09-02-2004 08:00 PM
Water, Water Everywhere Tania Aebi Cruising Articles 0 06-14-2004 08:00 PM
