09-16-2007
I wouldn't put a check valve in the line, since a check valve increases the work the engine water pump has to do to get water into the engine—not generally a good idea.
Also curious, but why did you not close the raw water intake on the boat before hauling it???
As the others have said, it should self-prime, and if it isn't self priming, then you've probably got something else going on.
