Old 09-16-2007
landlockvasailor's Avatar
landlockvasailor is on a distinguished road
Barrier Coat Petit vs Interlux
I would like an opinion on which appears to work well in both fresh and saltwater.
I have used both, but not with dual use.
Thanks
Tom
http://landlockedvasailor.blogspot.com/
When I go, let it be by boat, with a steady breeze on the Chesapeake with a bottle of 7-up, a bag of ice, a plastic cup, and a box of wine
Old 09-16-2007
six of one, half-dozen of the other... get which ever is less expensive. I used the Interprotect 2000E on my boat, but have used the Petit on others.
Old 09-16-2007
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
Talking
I wonder...?
If you used both in alternating layers would you have the ultimate barrier coat? Kidding of course
Old 09-16-2007
or none at all, depending on how compatible the two paints are...
Old 09-19-2007
Barrier
I chose to go with the 2000e after talking speaking with Bluewater Yatch in Hampton.
Also to share, I went to World Panel in Windor NC today. Unbelieveble they have all kinds of wood and are very helpful. I bought several sheets of HydroCore BS1088 Marine Plywood 2440 x 1220. Though they have teak plywood, Al, the manager, counseled that this would be just as good but a lower price.
Should anyone need formica, they are overstock and trying to move at a very small charge. All kinds of colors.
Finally, it is a trip to get there. It was a four hour drive from my house.
Old 09-19-2007
A good paint is Jotun Teflon....makes the boat go faster, too..
Old 09-19-2007
Thank you for the recommendation
Old 09-20-2007
billangiep's Avatar
billangiep is on a distinguished road
I choose 2000E because of the over coating time's and also it came in white or gray for alternating coats to make sure you have good coverage.
http://www.yachtpaint.com/USA/hotlin...t_bulletin.pdf
Old 09-20-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
I used the petit Vivid paint for the first time this year. Great colors, still don't know how well it works.
S/V Scheherazade
Old 09-20-2007
Keeping either paint well mixed is very important. The additives that either paint use tend to settle out fairly quickly, so you need to keep stirring the paint as you're applying it.
Barrier Coat & Antifouling paint shipley Gear & Maintenance 7 08-09-2009 09:18 AM
Barrier Coat - Amerlock 400 by Ameron ? dougshipl Gear & Maintenance 5 12-31-2007 01:10 AM
Barrier Coat existentialsailor Gear & Maintenance 2 12-19-2004 03:56 AM
Is Vinyl Antifoul better over Epoxy Barrier Coat pds Gear & Maintenance 3 08-27-2001 12:27 PM
Barrier Coat stupidgringo Gear & Maintenance 0 08-23-2001 04:53 PM
