Mildew Smell! - Page 3 - SailNet Community
post #21 of 23 Old 09-25-2007
Ozone, while it does have some benefits in destroying mold, mildew and microbes.... can cause serious problems with asthma, as well as help form smog. You're much better off just ventilating the boat properly...
sailingdog is offline
post #22 of 23 Old 09-25-2007
I had intended earlier to mention that if you are still smelling mildew in your boat after trying numerous things to clean your cushions... you may have mildew elsewhere. We had to wipe everything and I mean everything down with a diluted bleech and water mix. Ventillation is key...including on the hard.
mygirls66 is offline
post #23 of 23 Old 09-25-2007
Broad Reachin'
kwaltersmi's Avatar
We pulled the cushions out of our boat, removed the vinyl covers and soaked the foam in a mild solution of bleach and laundry detergent. The bleach kills the mold spores while the laundry detergent gives them that nice "spring air" scent. I have also "spot cleaned" really nasty areas on the foam with a more concentrated bleach solution and Lysol and/or Febreeze.
Catalina 34
kwaltersmi is offline
mildew neophyte2006 Boat Review and Purchase Forum 12 11-29-2009 10:27 PM
Mildew, Moisture, and Winterization? DrB Boat Review and Purchase Forum 1 04-15-2007 10:59 PM
Bilge Mildew DFA Gear & Maintenance 0 11-08-2004 07:25 AM
Mildew & Fabric mikehoyt Gear & Maintenance 8 11-02-2002 07:16 PM
That Diesel Smell Mark Matthews Gear and Maintenance Articles 0 08-27-2001 09:00 PM
