09-16-2007
Peter, if the old adhesive failed, you can regule the liner. But if this is a foam rubber liner and the foam is breaking down (to powder) nothing will solve the problem until the old crumbly foam is removed.
3M's "No.77 Permanent Adhesive" is a spray that is made for these jobs, and can withstand the heat on the overhead. Other cheaper "spray rubber cement" brands may let go, I'd spend the extra two bucks for the 3M product.
Any permanent brush-on contact cement (base cove cement, traditional yellow contact cement, etc.) should also do the job but a spray makes it much easier.
With any of these products--if there is surface contamination and powdering foam, they will bond to that and fail. They all need clean (or at least "solid") surfaces to bond to.
