Old 09-16-2007
Mary51 is on a distinguished road
Inverter/Battery charger question (Basis!)
I have a battery charger/inverter that is "400 watts," "maximum output 800 watts." So far, I've only used it to charge my cell phone.
To figure out if its safe to use it to charge my laptop battery, etc., what do I look for?
Yes, I have a book on electrical systems, and I read it, and I understand it for a split second at a time. Then, it's gone . . . Sort of like contemplating infinity. You get your mind around it, and . . . then it's gone. (I found Catholic school boring. I contemplated infinity when I wasn't reading a novel behind my math/english/science book.)
Please, any basic "how to" response would be much appreciated. I know that the battery charger packs for everything have info about watts, but also about volts and amps, and therein lies my problem.
BTW, I never leave the charger unattended. I am VERY leery about any potential fire hazard.
Thanks.
Mary
Old 09-16-2007
Most laptop chargers are 65-100 watts...so you should be fine. BTW, it should say on the charger what the input amperage is... Multiply that by the 110 VAC, you'll get WATTS.
Watts = power = volts * amps
Old 09-16-2007
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
I use a 400 watt portable inverter to charge my laptop. I also use it for my electric razor, but unplug the laptop while doing so. You should be able to run the laptop on what you have.
Currently at 37 32 02 N 76 20 03 W , Fishing Bay, VA
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 09-16-2007
PBz-
Unless you're using a hedge trimmer to shave with, you should be okay on leaving the laptop and razor running at the same time. I doubt an electric razor draws even 100 watts.
Old 09-16-2007
Thanks!
Now if I have to motor, I'll have the up side of watching dvd's.
Old 09-16-2007
Rockter will become famous soon enough
MY olde laptop used 8 ampere at about 12V.
Multiply the two to get power...
power = 8*12 = 96 Watt
... so your inverter could run 34 of them.
Your cellphone will use far less than that.
You are very wise not to leave anything unattended that runs on electrickery.
Old 09-16-2007
Damn it, 4 of them... not 34 of them, sorry !!
FOUR of them.
Old 09-16-2007
I see your math skills are as good as your physics skills...
Another battery charger question Omatako Gear & Maintenance 1 09-13-2007 03:23 AM
Sizing a Battery Charger for Windlass Battery btrayfors Gear & Maintenance 9 04-11-2007 12:43 AM
Undersized charger question Newport41 Gear & Maintenance 7 04-07-2007 10:38 PM
batter charger related question.... razorseal Living Aboard 7 04-12-2006 02:16 PM
Multi-Bank Charger Installation titan151 Gear & Maintenance 0 06-29-2005 08:25 AM
