09-18-2007
I've seen both ways, but my 37 Endeavour has the shrouds out far enough they tie directly into the sides of the hull.
I had a friend with a 20 year old Bristol which had the shrouds tied through the coachroof to an internal bulkhead. The bulkhead was a sandwich of 3/4 plywood with thin fiberglass on both sides. He had leaks around the chainplates which were masked by the fiberglass, until the plywood rotted and a wind gust ripped out the chainplates. He was dismasted in the main channel of the Mississippi River, less than a mile from an approaching barge. His radio antenna, at the top of his mast, did not send out a signal while under his boat. He could not use his motor with his sails and rigging down there. He was lucky another sailor was close enough to see his plight, radio the barge Captain, and get a tow line on the Bristol. Had he been alone on the river, it could have cost him his life, because the barge captain was almost 1000 feet behind the bow of the first barge, and typical stopping distance for a loaded towboat is almost half a mile! Moral of the story -- check your chainplates for leaking, especially if bolted to a plastic covered bulkhead!
