I recently had the standing rigging replaced on my 1977 Catalina 27. The rigging survey suggested that it was original and in need of replacement.
After the replacement, I noticed that the side decks were flexing upwards where the aft lower shroud chain plates attach. This evening I noticed that the deformation has caused the coachtop sides to buckle slightly between the windows.
After seeing this I unwound the tension on the aft lower stays - they are now completely loose.
I also walked around the side decks around the chain plates and noticed several things. The deck creaks when I walk on it. There is very slight movement around the aft lower shroud chain plates. When tapping the area with the handle of a screwdriver, it sounds sharp around the chainplates - but a slightly lower noise from an area further away.
So - with this vague description, am I looking at a disaster?
Is this clear signs of core rot and delamination? Or is it simply an indication of the shrouds being too tight, and that retensioning at a lower tension will cause all to be fine?
Changing the tension is not likely to solve the problem. If the sides of the deckhouse (coachtop/cabin/whatever...) are buckling then there is some weakening that has occured.
If this is delamination, could it be delamination without water intrusion?
Certainly, the core and fibreglass may have seperated under the stress without rot having set in.
Is it fixable without recoring? Can I do the "drill some holes and inject epoxy trick?"
The best thing to do is to loosen the chainplate and use a very small screwdriver or some such to dig around in the core. If it's soft, then you'll probably need to recore. If not, then you might be able to drill and fill.
If you do end up drilling and filling, you need to remove the chainplates and anything else that is exerting any kind of force on the deck for quite a wide radius. Allow the boat to return to as near its original shape as it can.
Before you proceed, you'll need to get some very substantial backing plates/brackets. Ideally they will be 15 to 18" long, and shaped so that you are able to attach them to the main bulkhead (inside the boat)as well as the underside of the deck.
You'll need some for the top of the deck, however these can be a bit smaller, just flat plates, ideally about 1/4" or so thick. The holes on the top plates should correspond to the holes in the underplates, as you are going to sandwich the deck between them.
Your deck has been weakened a bit here, so you want to simultaneously strengthen it, and attempt to transfer as much of the stress load to the rest of the boat as possible.
Once you have these (probably custom items) you can proceed to drill and fill with low viscosity epoxy, and then put the plates on top and bottom but DON'T tighten them anymore than is required to get the deck flat and even between them. (Cover the nuts and through bolts with something to prevent the epoxy from adhering to them before you put them through the holes.)
Leave them until the epoxy has cured. Then remove the top plate and drill the hole out a bit bigger than the bolt ONLY in the top layer of fibreglass and the core - not the bottom layer. Close off the bottom of the hole with tape and fill the hole with epoxy. Let it set, and then drill a hole that is sized for the bolt through again. You now have an epoxy seal protecting your core.
If your deckhouse is still warped, try taking out a port and seeing if the core is wet or if it is just loose. If it's wet - you MIGHT be able to dig it out from the existing port hole, but if it's extensive, then you'll probably have to recore. It could also just have separated without rotting, in which case you can pump gobs of epoxy in there and then clamp it into shape while it sets.
NOTE: Cover the inside of your boat while you are working on it. The epoxy can be very messy stuff.
NOTE: If you are going to be using a lot of epoxy, remember that it gets hot as it cures, so you want to avoid filing a large void all at once. Do it in stages. It can get hot enough to damage the fibreglass if you try to do too much too quickly.
Good Luck - let us know what happens...
