09-18-2007
I don't discuss my member
Originally Posted by wmiii
I would like to connect a hose form my scuba tank to a regulator so that I can clean the hull, prop etc on my sailboat.
I have found an inexpensive regulator and 1st stage at Divers Supply and am looking to find a 50' air hose. I checked with Divers supply and they have them for $2 a ft plus the connectors ($8).
Would a 50' air hose from Lowes ($20) work as well?
Also what about the connections?
Any input would be helpful
If you value your health you won't consider using anything but air hose designed to provide breathing air. That means stay away from pneumatic hose from the hardware store. Don't cheap-out when it comes to underwater breathing gear. If a hundred bucks is too much to spend on keeping yourself alive and healthy underwater, look on ebay. People are always selling used hose assemblies there.
"Clean bottoms are FastBottoms"
